can we use a record producer to create an incident using script
Shiva Kumar8
Hi Community,
is there a way I can create an incident using a record producer using script. if yes please help me.
Thanks.
but why do you wish to populate variables?
User is not submitting record producer but having chat with VA
When submission happens via record producer then variables are populated
have a look on this for how to submit record producer via script; this might help you
How to Trigger change workflow/record producer from transform script
13 REPLIES 13
so what all information you are asking from user via VA?
that record producer must be having some variables; ask same information to user and create incident using script
Hi Ankur,
I'm creating incident using normal incident creation script below, Im able to populate few fields but not the variables, can you help me how yo pull the variables
the variables are:
1. impact
2.please specify the application
3.description
(function execute() {
		gr.initialize();
		gr.caller_id = gs.getUserID();
		gr.opened_by = gs.getUserID();
		gr.short_description = vaInputs.description;
		gr.description = vaInputs.description;
		gr.business_service = "a8c4c649dbf94740b0463c9b7c961914";
		gr.cmdb_ci = vaInputs.application;
		gr.assignment_group = "0ae2acefdbce0f0067e1dd3b5e96199b";
		gr.contact_type = "self-service";
		gr.impact=vaInputs.impact;
		gr.insert(); //insert the new record
@Shiva Kumar
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
DanielCordick
Mega Patron
Hey Shiva,
A record producer creates a ticket on any table you specify for the record producer, no need to create a script to do this
Record Producer | ServiceNow Docs
please mark helpful or correct 🙂
