EC Pro Mega-menu: How to view fourth-level topics?
Yann_Dubois
Our taxonomy topics go down 4-levels, with content on the 4th level.  We want to display the 4th-level topics in the mega menu, but I haven't been successful in doing so.  Even with content in the fourth-level topics and syncing the menus with the taxonomy, I'm not getting them to appear under the 3rd-level headings.
According to the release notes this should be in EC Pro since Nov of 23:
The APN record is Active for the portal, and I verified that the sub-menus underneath are active as well, down to the 4th level.  I ran the "Sync hierarchy" UI action for each menu item, hoping that would pull in the 4th level items, but they weren't pulled in.  The topic records for these 4th level items are active, and they actually show up on the topic pages of the 3rd level topics, just not in the mega-menu.
We are on Vancouver and EC Pro is updated to the latest store release.
What might I be missing?
16 REPLIES 16
You can also go to Content Taxonomy > Taxonomies and edit the Employee taxonomy there as well.
I'm still unsure how to do what's been done for Help Center in the employee center pro, where one of the navigation menu items has the Employee taxonomy under it. The parent navigation item is read only, so I can't just re-parent the menus. Has anyone else found a way around this?
Are you in right scope?
I am in the correct scope, there's an access control that prevents updating the parent_item on the form. Is there somewhere else it can be updated from?
I found the problem I was having, for some reason our instance is missing the acl that allows you to edit the Source when creating a new advanced portal navigation item.
sanjanasinha
How to configure the mega menu to left or right
