Flow Designer to create reference record in Custom Table
karthik65
i have tried to create the Custom table with Reference value both catalog form and table field are reference field location. Flow designer create/update record method.
9 REPLIES 9
Hi @karthik65 ,
Seems you have 2 location field on form, hopping you are checking the right one.
Displayed sysid is present in location table, did you check that?
Yes it is a reference field in catalog item and custom table. the sysid exists in the location table. one field is location name and another one is location city.
Sysid is only getting captured in the table.
PrashantLearnIT
Tera Sage
Hi @karthik65
Please verify whether you are in the same referenced location field as the population location.
Please appreciate the efforts of community contributors by marking the appropriate response as the correct answer and helpful. This may help other community users to follow the correct solution in the future.
Cheers,
Prashant Kumar
Community Profile LinkedIn YouTube Medium TopMate
@PrashantLearnIT   The field is same as the form. i can see the sysid is passing but the table field is not getting updated.
FYI The table field is a reference field.
