Need help in finding OOB Feedback modal #yokohama
Rangana Ganesh
Could you someone help me where i can find the OOB Feedback modal as below when user clicks on yes & No,
Thanks in Advance.
@Rangana Ganesh
The one you shared is specific for ServiceNow Docs website and not for ServiceNow instances.
That will not be available in ServiceNow widgets or anywhere else in the instance. You will need to build a custom widget if you need one as such.
Accept the solution and mark as helpful if it does, to benefit future readers.
Sumanth
Similar one i found from below Prod documentation link, but unable to find the widget details.
https://www.servicenow.com/docs/bundle/yokohama-release-notes/page/release-notes/family-release-note...
