What causes cross-scope errors in record producer?
k_47
I can't set a value for variables in the server script of Record producer.
The following script is included in the server script.
producer.u_record_producer_variable = value;
As a result, the following error was returned.
ErrorAccess to api 'put(sys_user.u_record_producer_variable)' from scope 'aaa' has been refused due to the api's cross-scope access policy.
aaa is the scope containing the record producer.
Do you know how to get rid of this error?
Thank you in advance.
Ankur Bawiskar
@k_47
you can't set producer variable from record producer script
why to have duplicate question in community?
you already raised one sometime back
Get the sys_id of the target record to set to the ... - ServiceNow Community
Sorry. The title of the question was not good.
I wanted to ask about the cause of the error.
@k_47
you want to set record producer variable from record producer script?
if yes then not possible
You can use after insert BR and update the variable
