Even approver has not approved it is showing "No longer required" nothing is configured for that
02-10-2025 05:16 AM
Hi Team,
We have flow for RITM in which after submitting RITM we are sending 1st level approval and if that gets approved we are sending 2nd level approval and its a group approval, only anyone from the group approves then task should get created,
Issue here is for few RITM's task is getting created even though the 2nd level approval is not approved, showing the status "No longer required" showing updated by system.
but when we see the flow context it is showing approval completed true
Attaching screenshot
02-11-2025 04:52 AM
Is it possible for you to create a ticket specifically to test the functionality of the flow with BR disabled?
If I've at all helped, please return the favor by clicking the thumb next to my post. Thanks!
