hide Mandatory checkbox under portal settings using script
10-28-2025 06:36 AM
I have requirement if submitter authoorised selected as No , it should hide attachments , but as it was mandatory on the poratl settings level , how can i hide attachments
10-28-2025 06:48 AM
You need to create the catalog policy for this and make the necessary logic changes.
10-28-2025 07:21 AM
then don't make the attachment mandatory in portal settings.
Use onSubmit catalog client script and see the variable value and then make attachment mandatory
function onSubmit() {
try {
var count = getRPAttachmentCount();
if (window == null) {
// portal
if (count == 0 && g_form.getValue('variableName') == 'yes') {
alert('You must add attachment before submitting this request.');
return false;
} catch (ex) {
// native view
var length = getSCAttachmentCount();
if (length == 0 && g_form.getValue('variableName') == 'yes') {
return false;
function getRPAttachmentCount() {
var length;
try {
length = angular.element("#sc_cat_item_producer").scope().attachments.length;
} catch (e) {
length = -1;
return length;
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
10-28-2025 07:26 AM
@Ankur Bawiskar
But it should be mandatory on catalog item , but when sumitter field is selcted with no add attachments should get hided , hence preventing the user from submitting the request
10-28-2025 07:44 AM
you cannot hide that bottom attachment thing.
the only way is the approach I shared.
That will work for you.
