hide Mandatory checkbox under portal settings using script
10-28-2025 06:36 AM
I have requirement if submitter authoorised selected as No , it should hide attachments , but as it was mandatory on the poratl settings level , how can i hide attachments
10-28-2025 11:23 PM
can u help me with the code if the submitter field is yes then only make attachment mandatory , if no it should not be mandatory
11-05-2025 10:34 PM
I have written on change client script to show the error message and even if the attachemnts are mandatory it is not throwing an error message , Thanks for the help
10-28-2025 08:05 PM
Hope you are doing good.
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
10-28-2025 11:00 PM
10-28-2025 11:08 PM
that's OOTB method coming from platform level and you need not worry.
Is my script working fine for you?
