hide Mandatory checkbox under portal settings using script
10-28-2025 06:36 AM
I have requirement if submitter authoorised selected as No , it should hide attachments , but as it was mandatory on the poratl settings level , how can i hide attachments
10-28-2025 11:10 PM - edited 10-28-2025 11:12 PM
i have removed mandatory attachment from portal settings and added the on submit client script onto the catalog item , still it is not working , if the submitter is no , then it should make attachment non mandatory and if it yes then attachment should be mandatory and we are using employee portal
10-29-2025 08:15 PM
I already shared the code, you just need to add correct variable name and drop down to compare
function onSubmit() {
try {
var count = getRPAttachmentCount();
if (window == null) {
// portal
if (count == 0 && g_form.getValue('variableName') == 'yes') {
alert('You must add attachment before submitting this request.');
return false;
} catch (ex) {
// native view
var length = getSCAttachmentCount();
if (length == 0 && g_form.getValue('variableName') == 'yes') {
return false;
function getRPAttachmentCount() {
var length;
try {
length = angular.element("#sc_cat_item_producer").scope().attachments.length;
} catch (e) {
length = -1;
return length;
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
10-29-2025 08:23 PM
I tried this code but it didn't work
11-05-2025 10:29 PM
Hope you are doing good.
11-11-2025 01:54 AM
