05-05-2026 09:10 AM
I am using a flow for a catalog item, where there is a variable which contains an object which has an array.
And I need to generate approvals dynamically based on the length of the array.
So I though of creating a flow variable of array type and using set flow variable I will be able to parse that variable and set the variable with the array, but I do not see any option of wrting a script. The option appears for string type of variable. Any pointers will be appreciated thanks.
05-05-2026 09:26 AM
05-05-2026 08:52 PM
05-05-2026 11:01 PM
Hello @suvro ,
You can create a custom action in which pass your array as input through flow.
And for generating dynamic approvals use this script for output..
var arr = inputs.approvalArray || [];
if (arr.length > 0) {
outputs.result = 'ApprovesAnyU[';
for (var i = 0; i < arr.length; i++) {
outputs.result += arr[i];
if (i < arr.length - 1) {
outputs.result += ',';
outputs.result += "]";
outputs.result = 'No approvers provided';
})(inputs, outputs);
You will get the output as (comma seperated sys_id's - directly passing into the Ask for approval action) :
ApprovesAnyU[5137153cc6112xxxxx00bbdxxxxxxx07,d1f6fd36c37xxxxxxxx275e40131d5]
