How do I write a variable display name to work notes in Flow Designer
RichardSaunders
I have a Create Task Action and i am trying to set the work notes. But it is showing as sys_id.
Ankur Bawiskar
@RichardSaunders
if your variable is reference type then you dot walk to the fields within that table and use that in work notes
You can also use Lookup Record on the table being referred by that variable and then use output of that in the notes of your task.
