Client Script is not working in HR agent workspace - dialog box
Options
10-17-2025 03:38 AM
I’m using a client script to display a dialog box whenever a user manually changes the state to Closed Incomplete. The dialog box appears correctly, and I can capture the reason, but the entered reason is not being saved to the u_closure_reason field after saving the record.
if there is any solution or you have also crossed same issue, help me to understand the problem,
Thank in Advance
Thank in Advance
Options
10-22-2025 02:58 AM
what's your business requirement?
Options
10-22-2025 03:07 AM
when we change the state to closed incomplete the diaog box should appear with list of reasons, if we select any of the reason and click ok and save the state should close incomplete and the closure reason field should be visible in the form with selected value which we did in dialog box,
now the problem is the value we select in dialog box is not appearing in the closure reason field
