Block delegation for a particualar scope
rishabhkata
In 'sys_user_delegate' table there are below checkboxes:
1. Approvals
2. Assignments
3. All Notifications
4. Meeting invitations
5. HR Approvals
6. HR Notifications
Whenever a user checks HR Approvals and HR Notifications in the record then only HR specific notifications and approvals should trigger to that user (I have already implemented this using Granular delegation), Now I want to block sending HR specific notifications and approvals whenever a user selects "Approvals" and "All Notifications". Can anyone help in implementing this?
Hi @Dr Atul - LNG,
Is there any way we can modify Delegation scripts to meet our requirements?
Hi @rishabhkata
No, mate, I wouldn’t recommend that. You added your own checkbox, and if you find a solution, it will impact the whole platform, as delegation can also be used in ITSM. So, there's no way to go ahead with this, mate.
