Check Portal Cart before check out with OnSubmit client script
aneta_koleva
I am having the following requirement: to have a portal with attached service catalog. I need to do prevalidate on the cart to check if the current user is having enough amount of money for the ordered cart total price.
I was planning to create an onSubmit client script for the sc_cart using GlideAjax in order to check the cart items and their price.
But it wasn't working.
I have read that client scripts are not working with portals and indeed I have added an onLoad client script on sc_cart table but nothing is happening on the portal but only on the table itself in a particular record:
Portal:
what can be done in my case? any ideas are welcome.
Mark my answer Helpful in case you find it as such.
aneta_koleva
I have cloned the Shopping cart page's widget 'SC Shopping cart' (sc-shopping-cart-v2)
and done the behavior there.
Honestly I have no idea, you need to try. But I have the feeling that where you want to use it is not the same kind of element/component and may not be useful.
This Cart field is referencing the UI Macros.
