Converting from LDAP to LDAPS
Mike McCall
Giga Guru
I've been reading through the Wiki and the Community, but I just cannot figure out why I'm unable to successfully move from LDAP to LDAPS.
Right now, we have a working [un-encrypted] LDAP connection (and we have a VPN tunnel setup, if that's relevant). I uploaded and validated a new certificate, but as soon as I check the SSL box, I get the following error:
"Server Operational Status is false
Verify server address and port are correct and accessible"
What am I not doing (or doing wrong)?
15 REPLIES 15
bernyalvarado
Hi Michael, i once created a presentation of how to do a LDAPS setup. Take a look and see if it's helpful.
One aspect to point out is that your server url should be something like the following:
Use LDAPS://your-host-name:636/
Berny
Hi Michael, i couldn't find how i can attach the presentation to a post response
Feel free to email me at balvarado@volteo.com and I will send you the presenation via email.
Berny
Can you use an IP for "your-host-name," or does that cause issues with certificate verification (or other parts of the connection)?
Hi Michael, this needs to be the IP on which your LDAP (AD) server can be reached. The URL in this field should also match with the one specified in the Certificate.
Berny
That could be our issue (or one of our issues): we have an external IP listed in the Server URL, but the certificate uses the internal host name.
How have you approached this disconnect when setting up your LDAPS connection?
(I know you offered to send me a helpful video, but I'm hoping we can get things ironed out in this post. Maybe someone else with the same questions will reference this in the future!)
