Creating a variable inside task in flow design
Options
09-14-2023 07:01 AM
I am working on a flow design. Creating a task in the flow design itself.
I need to create a variable in that task in the flow design itself which is having 2 values yes and no.
Can anyone please help me out. It is urgent.
Options
09-14-2023 07:11 AM
@abhisek Could you please explain the exact use case here? What is the intent behind creating the variables inside the flow designer?
Options
09-14-2023 07:14 AM
Hi Sandeep,
That is the requirement.
Thanks&Regards,
Abhisek Chattaraj.
