Flow is triggered for custom RITM
dhivyal94299399
Requirement:
I have a Service Catalog form that contains an MRVS (Multi Row Variable Set). Once the user submits the form, for each MRVS row, a separate RITM should be created under a single Request.
Problem:
The RITMs are being generated successfully using a custom Flow Designer action for each MRVS row. However, the issue is that the Flow Context from the parent/original RITM is getting attached to the newly created custom RITMs as well. Because of this, the flow gets retriggered for the custom RITMs, approvals and catalog tasks are generated again, and the process goes into an infinite loop.
  • However, after completion, the Flow Context from the parent/original RITM gets attached to the custom RITMs automatically. Due to this, the approvals and catalog tasks start triggering again from the beginning for the custom RITMs, causing the flow to loop continuously.
Expectation:
  • One Request should contain multiple RITMs (one per MRVS row)
  • Newly created custom RITMs should not inherit or attach to the original Flow Context
script custom action script:
    var mrvs = inputs.mrvs;
    var ritm = new GlideRecord('sc_req_item');
    ritm.get(inputs.ritm);
    var createdRITMs = [];
    for (var i = 0; i < mrvs.length; i++) {
        var row = mrvs[i];
        var applicationName =
            row.select_module;
        var requestedForName =
            row.name;
        var roleName =
            row.select_role;
        var accessAction =
            row.select_access_type;
        // DYNAMIC SHORT DESCRIPTION
        var shortDescription = '[Offering] ' + applicationName +
    ' | [Role] ' + roleName +
    ' | [Action] ' + accessAction;
        // GET SERVICE OFFERING
        var so = new GlideRecord('service_offering');
        so.addQuery(
            'name',
            applicationName
        so.query();
        var serviceOfferingSysId = '';
        var businessServiceSysId = '';
        var assignmentGroup = '';
        if (so.next()) {
                so.sys_id.toString();
                so.parent.toString();
            assignmentGroup =
                so.parent.change_control.toString();
        // UPDATE EXISTING OOB RITM
        if (i == 0) {
            ritm.short_description =
                shortDescription;
            ritm.business_service =
                businessServiceSysId;
            ritm.service_offering =
                serviceOfferingSysId;
            ritm.assignment_group =
                assignmentGroup;
            ritm.stage =
                'Waiting for Approval';
            ritm.update();
            // UPDATE VARIABLES
            var existingMtom =
                new GlideRecord(
                    'sc_item_option_mtom'
            existingMtom.addQuery(
                'request_item',
                ritm.sys_id
            existingMtom.query();
            while (existingMtom.next()) {
                var existingOption =
                    new GlideRecord(
                        'sc_item_option'
                if (existingOption.get(
                    existingMtom.sc_item_option
                    var variableName =
                        existingOption
                        .item_option_new
                        .name
                        .toString();
                    // UPDATE NAME VARIABLE
                    if (variableName == 'name') {
                        existingOption.value =
                            requestedForName;
                        existingOption.update();
            createdRITMs.push(
                ritm.sys_id.toString()
        // CREATE NEW CUSTOM RITMS
        else {
            var newRITM =
                new GlideRecord(
                    'sc_req_item'
            newRITM.initialize();
            newRITM.request =
                ritm.request;
            newRITM.cat_item =
                ritm.cat_item;
            newRITM.requested_for =
                ritm.requested_for;
            newRITM.opened_by =
                ritm.opened_by;
            newRITM.due_date =
                ritm.due_date;
            newRITM.stage =
            newRITM.short_description =
                shortDescription;
            newRITM.business_service =
            newRITM.service_offering =
            newRITM.assignment_group =
                assignmentGroup;
            var newSysId =
                newRITM.insert();
            // COPY NORMAL VARIABLES
            var oldMtom =
                new GlideRecord(
            oldMtom.addQuery(
                'request_item',
                ritm.sys_id
            oldMtom.query();
            while (oldMtom.next()) {
                var oldOption =
                    new GlideRecord(
                        'sc_item_option'
                if (oldOption.get(
                    oldMtom.sc_item_option
                    var newOption =
                        new GlideRecord(
                            'sc_item_option'
                    newOption.initialize();
                    newOption.item_option_new =
                        oldOption.item_option_new;
                    var variableName =
                        oldOption
                        .item_option_new
                        .name
                        .toString();
                        newOption.value =
                            requestedForName;
                        newOption.value =
                            oldOption.value;
                    var newOptionSysId =
                        newOption.insert();
                    var newMtom =
                        new GlideRecord(
                    newMtom.initialize();
                    newMtom.request_item =
                        newSysId;
                    newMtom.sc_item_option =
                        newOptionSysId;
                    newMtom.insert();
            // COPY MRVS VALUES
            var mrvsGR =
                new GlideRecord(
                    'sc_multi_row_question_answer'
            mrvsGR.addQuery(
                'parent_id',
                ritm.sys_id
            mrvsGR.query();
            while (mrvsGR.next()) {
                var newMrvs =
                    new GlideRecord(
                newMrvs.initialize();
                newMrvs.parent_id =
                    newSysId;
                newMrvs.parent_table_name =
                    mrvsGR.getValue(
                        'parent_table_name'
                newMrvs.question =
                    mrvsGR.getValue(
                        'question'
                newMrvs.variable_set =
                    mrvsGR.getValue(
                        'variable_set'
                newMrvs.item_option_new =
                    mrvsGR.getValue(
                        'item_option_new'
                newMrvs.row_index =
                    mrvsGR.getValue(
                        'row_index'
                newMrvs.value =
                    mrvsGR.getValue(
                        'value'
                newMrvs.insert();
            createdRITMs.push(
                newSysId.toString()
    outputs.created_ritms = createdRITMs;
    gs.log("rimt number"+createdRITMs);
})(inputs, outputs);
dhivyal94299399
this is the where the flow context is getting attached and again manager approval is generated
Tanushree Maiti
Hi @dhivyal94299399
Use After Insert BR or flow to run this script:
              try{
var mrvsJson = current.variables.your_mrvs_internal_name;
var parsedData = JSON.parse(mrvsJson);
for (var i = 0; i < parsedData.length; i++) {
    var cart = new sn_sc.CartJS('cart_' + i);
    var item = {
        'sysparm_id': 'sys_id_of_catalog_item',
        'sysparm_quantity': '1',
        'variables': {
            'variable_name': parsedData[i].mrvs_field_name
    cart.orderNow(item);
              catch(e){
                             gs.info(e);
})(current, previous);
Tanushree Maiti
Ankur Bawiskar
@dhivyal94299399
what's the business requirement for creating multiple RITMs under same REQ?
Also the RITMs you are creating while iterating MRVS are for which Catalog item?
If same then yes the same flow will get attached to the newly created RITMs, that's OOTB behavior
@Ankur Bawiskar
Since they have  MRSV which has module, for each module, they wanted to create a separate RITM and that ritm has approval.
