How can I fix the standard ticket configuration to resolve it?
ayano
Giga Guru
I get an error like this when I click the Resolve button.
How do I enter the Resolution Code and Close Notes from the ticket page of the Service Portal?
Kasi Ramanathan
Hi @ayano ,
Hard code the Resolution note and Close Code in Incident Standard Ticket Actions.
Navigate to Service Portal --> Widgets.
Search for Incident Standard Ticket Actions. Open the record.
In the server script, hardcode the values for the fields as required.
	/* Actions - Start */
    if (input && input.action == 'resolveIncident' && incidentGr.get(incidentSysId)) {
        incidentGr.incident_state = global.IncidentState.RESOLVED;
		incidentGr.state = global.IncidentState.RESOLVED;
		incidentGr.resolved_by = gs.getUserID();
		incidentGr.close_notes = "Hard Code"; //Change the value as per your requirement
		incidentGr.close_code = "Hard Code"; //Change the value as per your requirement
		data.isIncidentResolved = incidentGr.update();
Screenshot:
Thank you for the wonderful answer before.
I want to ask one more things.
I want to modify Incident Standard Ticket 's widget to create a cancel option.
Could you answer here?
I want to create an option for the Cancel button under the Resolve button on the ticket page of the ...
If you give me a detailed script, I'll give you a'Mark as Correct Answer'.
Hi @Kasi Ramanathan ,
We are displaying the incidents in the portal for the users , if the logged in user is either 'Opened by' or 'Caller' or custom field 'Requested for'.
I need help in achieving the following:
1. I want the Resolve action to be available in the widget only for the user, if his name is in 'Requested for' field.
2. I want to hide the action if the logged in user is not the one who is in 'Requested for' field.
Please help me with this.
Talya
