How to add custom stages to RITMs but using catalog builder
Options
03-03-2026 06:41 AM
Dear Team, am using Step based request fulfillment
flow in catalog builder and have built a catalog item, on RITM I see that the flow stages are as follows
Service fulfillment process (Completed) ,
Closed Incomplete (Skipped),
Completed (Completed)
Is it possible to make it more catalog item specific or add additional stages without having to customize the base flow Step based request fulfillment as this flow is read-only.
Labels:
Service Catalog
Options
03-03-2026 10:25 AM
Hi @VaranAwesomenow ,
Doesn't sounds like you're an admin, as you don't have edit rights to the flow behind. I would recommend you to reach out to your admins for this requirement.
Options
03-06-2026 09:07 AM
ServiceNow OOB makes few objects as read only this is one of them.
