How to add machine path location in servicenow catalog variable
08-21-2023 07:43 AM
Hello, @Sagar Pagar ,
Like i have a catlog item in it i have one varibable called test if i click on the test as yes then it will redirect to my system path location it is " C:\Program Files" this on its not an URL so can you please help me onthis ...
Once if i slect the choice as yes then auomatically it will show our system path location ...
Haresh
08-21-2023 07:57 AM
Hi @Haresh Haru,
You need to create Rich text label variable, where you will store your system path location.
Create a Catalog UI policy and if your variable choice is yes, then make it visible.
If my response helps to solve your issue. Kindly mark it as helpful & correct. It will be helpful for future readers! 👍🏻
Sagar Pagar
08-21-2023 08:02 AM
Hello @Sagar Pagar ,
Like that file location is nothing but we have several apps download list if i click on that link it should show that link in dynamically then we can see several applications post that we can download it that is the objective that requirement like how we are giving the https:// www.google.com" instaead the URL it should open the File path where we can fimd the all items
Regards'
Haresh
