How to automate for notifying if a task isopened
Priyadarshini2
I want to send notification mail reminding that a task is opened. The mail should be sent every 6 hours until the task is closed. Please help its urgent
Siddhesh Gawade
Hello @Priyadarshini2 ,
You can use scheduled job, which will run on every 6 hour duration.
1. Create a new event from System Policy > Events > Event Registry. for example (sc_task.not_closed).
2.in schedule job script you can write similar code as given and modify it according to your requirement:
var gr = new GlideRecord('sc_task');  // user your task table
    // Query open tasks (tasks that are not closed)
    gr.addQuery('state', '!=', 3); // Assuming 3 is the "Closed" state (change as per your instance's configuration)
    // Loop through all open tasks
    while (gr.next()) {
        // Trigger the event if the task is still open
        gs.eventQueue('sc_task.not_closed', gr, gr.sys_id, gs.getUserID());
Go to System Notification > Notifications.
  • Create a New Notification:
  • Click New to create a new notification.
    • Set the following fields:
      • Name: Task Not Closed Notification
      • Table: sc_task
      • Active: Check this box to enable the notification.
      • When to send: Set this to trigger when the event is fired.
        • Event Name: sc_task.not_closed
Who will receive: Choose who will receive the notification. This could be the task owner or any other user/group. For instance, use the Assigned to field (Modify as per your requirement).
Kindly mark the answer ✔️ Correct or Helpful ✔️ If it addresses your concern.
Siddhesh
Ankur Bawiskar
@Priyadarshini2
why not use flow designer with no-code, low-code solution?
Something like this
@Priyadarshini2
Hope you are doing good.
