how to create 2 auto generate sequence number fields in single table?
Purvi Kotadiya
Giga Expert
Requirement- I have a table 'test' and I would like to create 2 auto generate number fields. For ex: 1st-> test00001 (default)
2nd- > currentyear/01, currentyear/02 and so on should be auto generated based on certain conditions.
Can I have 2 number maintenance records for the same table as it doesn't have field name or any other approach?
Tanushree Maiti
Hi @Purvi Kotadiya
For  1st field (e.g u_custom_num_1) , you can enable auto numbering . (refer: Auto-Numbering Records: How it works and how to remove it)
For 2nd field - If you do not need the number to be generated prior to inserting the record, in that case you can ,you can  use before insert Business Rule .
Sample code - //not tested.
    if (current.category == 'hardware')   // Add your condition if any
{ current.u_custom_num_2 =
"currentyear/" + current.number.toString().slice(-2) ; //with currentyear you can append 1st field's last 2 digit. } })(current, previous);
Tanushree Maiti
Tanushree Maiti
Hi @Purvi Kotadiya
Tanushree Maiti
Thanks @Tanushree Maiti , This solution works 😀
