How to create Project defination in project portfolio management
Asha Pathak
Hello community!
I have the requirement to create project definition and given information as below
Project Definition
  • Effort >200 hours; or
  • Budget >$50K; or
  • Significant collaboration w/ another HQ IT team; or
  • High impact / risk
when I try to create budget on instance, it is read only and shows 0.
How to modify the amount?
prsudhakar123
Dear @Asha Pathak
Good day ! Hope you are doing great ..
Request you to use the " Cost Plan" tab in the related tab which will automatically update the " Financials" section at the top.
