‎08-04-2022 04:57 AM
Hi Everyone,
I need to stop triggering notification multiple time from scheduled job.
script:
var gr = new GlideRecord("cmdb_ci_business_app");
gr.addEncodedQuery('assigned_to.active=false^assigned_to.sys_updated_onONLast 7 days@javascript:gs.beginningOfLast7Days()@javascript:gs.endOfLast7Days()');
while (gr.next()) {
gs.eventQueue('fa.business.app.accountable.owner', gr, gr.assigned_to.manager.email, gr.assigned_to);
var gr1 = new GlideRecord("cmdb_ci_service_discovered");
gr1.addEncodedQuery('assigned_to.active=false^assigned_to.sys_updated_onONLast 7 days@javascript:gs.beginningOfLast7Days()@javascript:gs.endOfLast7Days()');
gr1.query();
while (gr1.next()) {
gs.eventQueue('fa.business.app.accountable.owner', gr1, gr1.assigned_to.manager.email, gr1.assigned_to);
‎08-04-2022 06:15 AM
Example:
1) I push assigned to and assigned to manager into array and sent as parameter1.In the notification check the check box recipient contains parm1 under whom to send
2)Then i push all the business app names into an array and sen as parameter 2
var bussinessArr=[];
var bussRecipients=[];
while (gr.next()) {
bussinessArr.push(gr.name.toString());
bussRecipients.push(gr.assigned_to.manager.toString());
bussRecipients.push(gr.assigned_to.toString());
gs.eventQueue('fa.business.app.accountable.owner', gr, bussRecipients , bussinessArr);
Now create a email script like below
(function runMailScript(/* GlideRecord */ current, /* TemplatePrinter */ template,
/* Optional EmailOutbound */ email, /* Optional GlideRecord */ email_action,
/* Optional GlideRecord */ event) {
var busApps = event.parm2;
template.print('please find the Business apps which are assinged to users whoc are incative under you');
for(var i=0;i<busApps.length;i++)
template.print("Business App :"+i+" "+ busApps[i]);
})(current, template, email, email_action, event);
Then call this email script in your notification as ${mail_script:your_mail_Script_name}
this way you can send a single notification to inactive users managers with multiple records
Hope this helps
please mark my answer correct if this helps you
‎08-04-2022 09:46 PM
Thank you so much for your answer. I had the same problem. Scheduled job was triggering multiple emails and now I used gs.eventQueue outside the loop that helped. Now it has stopped the multiple notifications.
I have provided the email in the users - whom to send in the notifications. Do I still need to check the parm1? It is going to the correct person from the email.
Your answer was very helpful for me. Really appreciated you explaining in detail.
Thank you
Shubha
‎08-04-2022 05:35 AM
This scheduled job will trigger notifications to all Inactive assigned to users for Business App and Service Discovered so what's issue exactly here?
Abhijit
ServiceNow MVP
‎08-04-2022 06:03 AM
I need to send notification for inactive user's manager in assigned_to field where it can be multiple records on business application for same user, but I need to send only one notification to inactive users manager. but it's triggering multiple times because multiple of records. so, That's the issue I am facing here.
‎08-04-2022 06:38 AM
To help you further, I need to know what is the content of the notification. Does it include any field details from the Business Application or Service Discovered record?
Abhijit
ServiceNow MVP
