How to track all scripts , Ui Actions , Ui plicies when I click Save in sc_task SOW form?
Nabil EL FILALI
Could you please help with this topic?
When the “Assigned to” field is empty and I click “Save”, it should normally display an error message, but that is not the case. How can I track any executed code or policy that might affect this behavior?
Thanks.
AndersBGS
Hi @Nabil EL FILALI ,
Has it worked earlier and stopped working or?
Best regards
Anders
Rising star 2024
MVP 2025
Tanushree Maiti
If it was working earlier and not working now, check  recent what  has updated in in the catalog item.
Check  difference between working version and current version.
Check onSubmit client script on sc_task  if you had error msg set there.
Tanushree Maiti
rajshinde999910
Hello @Nabil EL FILALI ,
If you want to find where a specific message is being triggered from, and you are using SN Utils, you can copy the message you are seeing and search for it. It will show you from where the message is being executed.
