MD5 hashing algorithm (Script Include)
12-20-2016 05:32 PM
var MD5Hashing = Class.create();
MD5Hashing.prototype =
initialize:function()
var hexcase = 0; /* hex output format. 0 - lowercase; 1 - uppercase */
var b64pad = ""; /* base-64 pad character. "=" for strict RFC compliance */
hex_md5:function(s)
return this.rstr2hex(this.rstr_md5(this.str2rstr_utf8(s)));
b64_md5:function(s)
return this.rstr2b64(this.rstr_md5(this.str2rstr_utf8(s)));
any_md5:function(s, e)
return this.rstr2any(this.rstr_md5(this.str2rstr_utf8(s)), e);
hex_hmac_md5:function(k, d)
return this.rstr2hex(this.rstr_hmac_md5(this.str2rstr_utf8(k), this.str2rstr_utf8(d)));
b64_hmac_md5:function(k, d)
return this.rstr2b64(this.rstr_hmac_md5(this.str2rstr_utf8(k), this.str2rstr_utf8(d)));
any_hmac_md5:function(k, d, e)
return this.rstr2any(this.rstr_hmac_md5(this.str2rstr_utf8(k), this.str2rstr_utf8(d)), e);
* Perform a simple self-test to see if the VM is working
md5_vm_test:function()
return this.hex_md5("abc").toLowerCase() == "900150983cd24fb0d6963f7d28e17f72";
* Calculate the MD5 of a raw string
rstr_md5:function(s)
return this.binl2rstr(this.binl_md5(this.rstr2binl(s), s.length * 8));
* Calculate the HMAC-MD5, of a key and some data (raw strings)
rstr_hmac_md5:function(key, data)
var bkey = this.rstr2binl(key);
if(bkey.length > 16) bkey = this.binl_md5(bkey, key.length * 8);
var ipad = Array(16), opad = Array(16);
for(var i = 0; i < 16; i++)
ipad[i] = bkey[i] ^ 0x36363636;
opad[i] = bkey[i] ^ 0x5C5C5C5C;
var hash = this.binl_md5(ipad.concat(this.rstr2binl(data)), 512 + data.length * 8);
return this.binl2rstr(this.binl_md5(opad.concat(hash), 512 + 128));
* Convert a raw string to a hex string
rstr2hex:function(input)
try {
hexcase ;
catch(e)
hexcase=0;
var hex_tab = hexcase ? "0123456789ABCDEF" : "0123456789abcdef";
var output = "";
var x;
for(var i = 0; i < input.length; i++)
x = input.charCodeAt(i);
output += hex_tab.charAt((x >>> 4) & 0x0F)
+ hex_tab.charAt( x & 0x0F);
return output;
* Convert a raw string to a base-64 string
rstr2b64:function(input)
try { b64pad } catch(e) { b64pad=''; }
var tab = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
var output = "";
var len = input.length;
for(var i = 0; i < len; i += 3)
var triplet = (input.charCodeAt(i) << 16)
| (i + 1 < len ? input.charCodeAt(i+1) << 8 : 0)
| (i + 2 < len ? input.charCodeAt(i+2) : 0);
for(var j = 0; j < 4; j++)
if(i * 8 + j * 6 > input.length * 😎 output += b64pad;
else output += tab.charAt((triplet >>> 6*(3-j)) & 0x3F);
return output;
* Convert a raw string to an arbitrary string encoding
rstr2any:function(input, encoding)
var divisor = encoding.length;
var i, j, q, x, quotient;
/* Convert to an array of 16-bit big-endian values, forming the dividend */
var dividend = Array(Math.ceil(input.length / 2));
for(i = 0; i < dividend.length; i++)
dividend[i] = (input.charCodeAt(i * 2) << 😎 | input.charCodeAt(i * 2 + 1);
* Repeatedly perform a long division. The binary array forms the dividend,
* the length of the encoding is the divisor. Once computed, the quotient
* forms the dividend for the next step. All remainders are stored for later
* use.
var full_length = Math.ceil(input.length * 8 /
(Math.log(encoding.length) / Math.log(2)));
var remainders = Array(full_length);
for(j = 0; j < full_length; j++)
quotient = Array();
x = 0;
x = (x << 16) + dividend[i];
q = Math.floor(x / divisor);
x -= q * divisor;
if(quotient.length > 0 || q > 0)
quotient[quotient.length] = q;
remainders[j] = x;
dividend = quotient;
/* Convert the remainders to the output string */
var output = "";
for(i = remainders.length - 1; i >= 0; i--)
output += encoding.charAt(remainders[i]);
return output;
* Encode a string as utf-8.
* For efficiency, this assumes the input is valid utf-16.
str2rstr_utf8:function(input)
var output = "";
var i = -1;
var x, y;
while(++i < input.length)
/* Decode utf-16 surrogate pairs */
y = i + 1 < input.length ? input.charCodeAt(i + 1) : 0;
if(0xD800 <= x && x <= 0xDBFF && 0xDC00 <= y && y <= 0xDFFF)
x = 0x10000 + ((x & 0x03FF) << 10) + (y & 0x03FF);
i++;
/* Encode output as utf-8 */
if(x <= 0x7F)
output += String.fromCharCode(x);
else if(x <= 0x7FF)
output += String.fromCharCode(0xC0 | ((x >>> 6 ) & 0x1F),
0x80 | ( x & 0x3F));
else if(x <= 0xFFFF)
output += String.fromCharCode(0xE0 | ((x >>> 12) & 0x0F),
0x80 | ((x >>> 6 ) & 0x3F),
else if(x <= 0x1FFFFF)
output += String.fromCharCode(0xF0 | ((x >>> 18) & 0x07),
0x80 | ((x >>> 12) & 0x3F),
return output;
* Encode a string as utf-16
str2rstr_utf16le:function(input)
var output = "";
output += String.fromCharCode( input.charCodeAt(i) & 0xFF,
(input.charCodeAt(i) >>> 😎 & 0xFF);
return output;
str2rstr_utf16be:function(input)
var output = "";
output += String.fromCharCode((input.charCodeAt(i) >>> 😎 & 0xFF,
input.charCodeAt(i) & 0xFF);
return output;
* Convert a raw string to an array of little-endian words
* Characters >255 have their high-byte silently ignored.
rstr2binl:function(input)
var output = Array(input.length >> 2);
for(var i = 0; i < output.length; i++)
output[i] = 0;
for(var i = 0; i < input.length * 8; i += 😎
output[i>>5] |= (input.charCodeAt(i / 😎 & 0xFF) << (i%32);
return output;
* Convert an array of little-endian words to a string
binl2rstr:function(input)
var output = "";
for(var i = 0; i < input.length * 32; i += 😎
output += String.fromCharCode((input[i>>5] >>> (i % 32)) & 0xFF);
return output;
* Calculate the MD5 of an array of little-endian words, and a bit length.
binl_md5:function(x, len)
/* append padding */
x[len >> 5] |= 0x80 << ((len) % 32);
x[(((len + 64) >>> 9) << 4) + 14] = len;
var a = 1732584193;
var b = -271733879;
var c = -1732584194;
var d = 271733878;
for(var i = 0; i < x.length; i += 16)
var olda = a;
var oldb = b;
var oldc = c;
var oldd = d;
a = this.md5_ff(a, b, c, d, x[i+ 0], 7 , -680876936);
d = this.md5_ff(d, a, b, c, x[i+ 1], 12, -389564586);
c = this.md5_ff(c, d, a, b, x[i+ 2], 17, 606105819);
b = this.md5_ff(b, c, d, a, x[i+ 3], 22, -1044525330);
a = this.md5_ff(a, b, c, d, x[i+ 4], 7 , -176418897);
d = this.md5_ff(d, a, b, c, x[i+ 5], 12, 1200080426);
c = this.md5_ff(c, d, a, b, x[i+ 6], 17, -1473231341);
b = this.md5_ff(b, c, d, a, x[i+ 7], 22, -45705983);
a = this.md5_ff(a, b, c, d, x[i+ 8], 7 , 1770035416);
d = this.md5_ff(d, a, b, c, x[i+ 9], 12, -1958414417);
c = this.md5_ff(c, d, a, b, x[i+10], 17, -42063);
b = this.md5_ff(b, c, d, a, x[i+11], 22, -1990404162);
a = this.md5_ff(a, b, c, d, x[i+12], 7 , 1804603682);
d = this.md5_ff(d, a, b, c, x[i+13], 12, -40341101);
c = this.md5_ff(c, d, a, b, x[i+14], 17, -1502002290);
b = this.md5_ff(b, c, d, a, x[i+15], 22, 1236535329);
a = this.md5_gg(a, b, c, d, x[i+ 1], 5 , -165796510);
d = this.md5_gg(d, a, b, c, x[i+ 6], 9 , -1069501632);
c = this.md5_gg(c, d, a, b, x[i+11], 14, 643717713);
b = this.md5_gg(b, c, d, a, x[i+ 0], 20, -373897302);
a = this.md5_gg(a, b, c, d, x[i+ 5], 5 , -701558691);
d = this.md5_gg(d, a, b, c, x[i+10], 9 , 38016083);
c = this.md5_gg(c, d, a, b, x[i+15], 14, -660478335);
b = this.md5_gg(b, c, d, a, x[i+ 4], 20, -405537848);
a = this.md5_gg(a, b, c, d, x[i+ 9], 5 , 568446438);
d = this.md5_gg(d, a, b, c, x[i+14], 9 , -1019803690);
c = this.md5_gg(c, d, a, b, x[i+ 3], 14, -187363961);
b = this.md5_gg(b, c, d, a, x[i+ 8], 20, 1163531501);
a = this.md5_gg(a, b, c, d, x[i+13], 5 , -1444681467);
d = this.md5_gg(d, a, b, c, x[i+ 2], 9 , -51403784);
c = this.md5_gg(c, d, a, b, x[i+ 7], 14, 1735328473);
b = this.md5_gg(b, c, d, a, x[i+12], 20, -1926607734);
a = this.md5_hh(a, b, c, d, x[i+ 5], 4 , -378558);
d = this.md5_hh(d, a, b, c, x[i+ 8], 11, -2022574463);
c = this.md5_hh(c, d, a, b, x[i+11], 16, 1839030562);
b = this.md5_hh(b, c, d, a, x[i+14], 23, -35309556);
a = this.md5_hh(a, b, c, d, x[i+ 1], 4 , -1530992060);
d = this.md5_hh(d, a, b, c, x[i+ 4], 11, 1272893353);
c = this.md5_hh(c, d, a, b, x[i+ 7], 16, -155497632);
b = this.md5_hh(b, c, d, a, x[i+10], 23, -1094730640);
a = this.md5_hh(a, b, c, d, x[i+13], 4 , 681279174);
d = this.md5_hh(d, a, b, c, x[i+ 0], 11, -358537222);
c = this.md5_hh(c, d, a, b, x[i+ 3], 16, -722521979);
b = this.md5_hh(b, c, d, a, x[i+ 6], 23, 76029189);
a = this.md5_hh(a, b, c, d, x[i+ 9], 4 , -640364487);
d = this.md5_hh(d, a, b, c, x[i+12], 11, -421815835);
c = this.md5_hh(c, d, a, b, x[i+15], 16, 530742520);
b = this.md5_hh(b, c, d, a, x[i+ 2], 23, -995338651);
a = this.md5_ii(a, b, c, d, x[i+ 0], 6 , -198630844);
d = this.md5_ii(d, a, b, c, x[i+ 7], 10, 1126891415);
c = this.md5_ii(c, d, a, b, x[i+14], 15, -1416354905);
b = this.md5_ii(b, c, d, a, x[i+ 5], 21, -57434055);
a = this.md5_ii(a, b, c, d, x[i+12], 6 , 1700485571);
d = this.md5_ii(d, a, b, c, x[i+ 3], 10, -1894986606);
c = this.md5_ii(c, d, a, b, x[i+10], 15, -1051523);
b = this.md5_ii(b, c, d, a, x[i+ 1], 21, -2054922799);
a = this.md5_ii(a, b, c, d, x[i+ 8], 6 , 1873313359);
d = this.md5_ii(d, a, b, c, x[i+15], 10, -30611744);
c = this.md5_ii(c, d, a, b, x[i+ 6], 15, -1560198380);
b = this.md5_ii(b, c, d, a, x[i+13], 21, 1309151649);
a = this.md5_ii(a, b, c, d, x[i+ 4], 6 , -145523070);
d = this.md5_ii(d, a, b, c, x[i+11], 10, -1120210379);
c = this.md5_ii(c, d, a, b, x[i+ 2], 15, 718787259);
b = this.md5_ii(b, c, d, a, x[i+ 9], 21, -343485551);
a = this.safe_add(a, olda);
b = this.safe_add(b, oldb);
c = this.safe_add(c, oldc);
d = this.safe_add(d, oldd);
return Array(a, b, c, d);
* These functions implement the four basic operations the algorithm uses.
md5_cmn:function(q, a, b, x, s, t)
return this.safe_add(this.bit_rol(this.safe_add(this.safe_add(a, q), this.safe_add(x, t)), s),b);
md5_ff:function(a, b, c, d, x, s, t)
return this.md5_cmn((b & c) | ((~b) & d), a, b, x, s, t);
md5_gg:function(a, b, c, d, x, s, t)
return this.md5_cmn((b & d) | (c & (~d)), a, b, x, s, t);
md5_hh:function(a, b, c, d, x, s, t)
return this.md5_cmn(b ^ c ^ d, a, b, x, s, t);
md5_ii:function(a, b, c, d, x, s, t)
return this.md5_cmn(c ^ (b | (~d)), a, b, x, s, t);
* Add integers, wrapping at 2^32. This uses 16-bit operations internally
* to work around bugs in some JS interpreters.
safe_add:function(x, y)
var lsw = (x & 0xFFFF) + (y & 0xFFFF);
var msw = (x >> 16) + (y >> 16) + (lsw >> 16);
return (msw << 16) | (lsw & 0xFFFF);
* Bitwise rotate a 32-bit number to the left.
bit_rol:function(num, cnt)
return (num << cnt) | (num >>> (32 - cnt));
- 6,530 Views
03-22-2023 03:35 AM
Hi brother Frank, it is useful but I can not apply it for Global Scope, do you have any advise for Global ?
Thank you!
03-22-2023 04:57 AM
I believe it works in Global. I just ran it in Scripts - Background (which I have read here always runs in Global) and it prints out the Hex MD5 hash of my string. Also, my current application scope is set to Global:
The exact script I'm running is:
Run script in Global is selected:
(In my reply above I forgot the terminating double-quote - I'll go back and fix that).
The result is:
