Multirow variable set is not showing on catalog task level
rohini23
Hello Everyone,
My multivariable set is showing at RITM level, but it is not showing on catalog task level,
Is there any latest thing came across SanDiego version.
Can anyone help me on this?
Thanks in advance,
Rohini Vibhute
Murthy Ch
Hi @rohini23
Did you tried to keep the MRVS in available section in slush bucket in catalog task activity.
Murthy
Hi @kumariDiksha
What is your issue? If you are using flow to create a catalog task for your catalog item. You can use the similar functionality to show the variables in the catalog task like below screenshot:
You just need to add the variables into the selected slush bucket.
Murthy
Syd S
Your reply helped me find the solution to my issue. The workflow was using the Create Task activity not the Catalog Task activity. I changed to Catalog Task and then had the option to select the MRVS. Tasks now show the MRVS as expected. Thanks!
Hope it worked!
Murthy
Do check the below Article :
MultiRow Variable Set Visiblity
Karthik R
