Need to split check boxes into two columns
anatara
Giga Contributor
I have to create a variable with 8 choices in the type of check boxes. I used container start,split and end but still im not meeting my requirement. After split variable.Option default Label is visible in the top of choice list.I need to remove on this default Option Labels.
Please help me.... Thanks in advance...
Valentina6
Giga Guru
Hi!
I don't know why, but the 'options' label doesn't appear with a variable set. Put the label, checkboxes and containers in a variable set:
Best Regards,
Valentina
13 REPLIES 13
Deepak Kumar5
try with Checkbox Label outside of the container.
Tried but no luck
roy_walton
Mega Guru
Add a new Label variable just after the container split, but just put a space in the Question field.
Hi Walton,
I am not able to give space to the variable question.It is not accepting.
Thanks and Regards,
Nirisha.
Question field is mandatory.
