Populate Values from reference type
Shri8
Hello @Shri8 ,
Try to update the line as or try without toString() function.
var temp=g_form.getValue('you_glide_list_field_name').toString() +','+newValue;
 Kindly let me know if there is any issue.
Shri8
Hi Sunny,
This is throwing error as "function toString() { [native code] }, ".
The requirement is when choosing value "X" in reference field then X should be populate in list field and if on changing X to Y in reference field then list field should populate value as X,Y. Please Suggest.
But, again, why are you wanting to do this?  There may be another way of doing what you actually need.
Hello @Shri8 ,
Shri8
Hi @Sunny3008
Thank you and script works.
