Portal script is not working properly
chandanpatra
Hi All , this script is not working properly :
HTML:
<div ng-if='c.data.matchfound' >
<p>Please select one of the service lounges below </p>
</div>
Server side:
var queueId = $sp.getParameter('location_id');
var gr3= new GlideRecord('wu_location_queue');
gr3.addQuery('sys_id',queueId);
gr3.addEncodedQuery('nameSTARTSWITHME^active=true');
gr3.query();
if(gr3.next())
data.matchfound='true';
gs.addInfoMessage('test')
else{
data.matchfound='false';
gs.addInfoMessage('fail')
In the HTML side it is not working fine
it will be
</div>
BK
LinkedIn: https://www.linkedin.com/in/bhavyashree-karanth-55032a121
YouTube: https://www.youtube.com/@NowWithBhavya
9 REPLIES 9
in server side update like below and try
gr3.query();
if(gr3.next())
data.matchfound=true;
else{
data.matchfound=false;
BK
I am telling to that SErver side script is working fine but the HTML side is not working and we are receiving the data "c.data.matchfound " correct data
</div>
its failing because you retuning as string from server side and comparing as Boolean value.
Please update the
it will work fine
BK
<div ng-if='data.matchFound ' >
</div>
It is not working
it will be
</div>
BK
