Reassign Open tickets to group and remove member from group when user is marked inactive
Atheher Fathima
Mega Guru
i have a requirement that whenever a user is marked inactive in sys_user table,
1. we need to check open incidents, tasks, problems and assign them to the group itself(make assigned to blank)
2.For any applications/CI where user is a owner/tech lead - generate a list and trigger notification
3.Remove the user from the group
I tried to create a scheduled job to remove members from group and created a BR on sys_user_grmember to reassign the open tasks to group.however i see that it is also removing assigned to for Resolved tickets as well and unable to achieve point 2.
below is my script
    var groupId = current.getValue("group");
    var groupName = current.group.getDisplayValue();
    var userId = current.getValue("user");
    var userName = current.user.getDisplayValue();
    //look for all Active Task records assigned to the Group AND User
    var grpm = new GlideRecord("task");
    grpm.addEncodedQuery("active=true^assignment_group=" + groupId + "^assigned_to=" + userId);
    grpm.query();
    while (grpm.next()) {
        //add a work note to let people know why the field was cleared
        grpm.work_notes.setJournalEntry("Assigned to field cleared because '" + userName + "' was removed from the current Assignment group '" + groupName + "'");
        grpm.assigned_to = "";
        grpm.update();
})(current, previous);
Can someone please help on how i can achieve this with a BR on sys_user table itself on when active changes to false? any help on this will be greatly appreciated
Martin Ivanov
Please mark Correct and Helpful if my answer helps you resolve your issue.
Тhis will close the thread and other users may also benefit from it.
Thanks!
Martin Ivanov
Community Rising Star 2022
atul_05
Hi @Atheher Fathima
Can you please share the flow that you have created to achieve this requirement. It will be really helpful.
