Report Issue - How to change Legend Label in reports?
shanker1
Giga Guru
I'm generating a Bar chart   to get the list of incidents that are breached and not breached by assignment group. I'm stacking by hasBreached field. So the legend of the report shows as false and true. Can this legend label be changed to SLA met and SLA not met?
Shanker
12 REPLIES 12
This is fine ,when we need to show numbers, but SLA make more sense to show in percentage , When i tried the same dataset doesn't provide right data. If anyone found a good way to show another way to rename the legends then please advise.
I have created data sets
- what kind of records have you created?
- and where did you save them?
In your main report you can give condition of has_breached is true and for the dataset you can condition as has_breached is false.
- where exactly are these conditions set?
- how are the dataset values assigned to the table?
Could you please give me a more detailed description of the procedure? Thanks a lot.
sthakur2in
Giga Contributor
Hello, How Can we create the Reports ( incoming vs Closed tickets ) in a month  ?
