Restirct a catalog field to allow alphanumeric values and not special characters
KS13
Hi
Hoping someone can guide me to write a simple onChange catalog client script.
Have a requirement, where a catalog field should allow alpha-numerical values and not allow special characters EXCEPT 'dashes' and 'dots/periods'
For example:
Allow: Test-123.com OR Test.123-456.
Restrict: Test-123$%^&.com
If allowed, set value, if Restricted, then throw an error message.
Thank you in advance
KS
VishalB06557037
Hi @KS13
Below is the script.
    var field_value = g_form.getValue('your_catalog_field'); // Replace 'your_catalog_field' with the actual field name.
    var regex = /^[a-zA-Z0-9.-]+$/; // Regular expression to allow alphanumeric, dashes, and dots.
    if (!regex.test(field_value)) {
        alert("Invalid input! Please use only alphanumeric characters, dashes, and dots.");
You can also do this with Validation regex option for this.
Vishal Birajdar
ServiceNow Developer
- Socrates
VishalB06557037
Hi @KS13
Vishal Birajdar
- Socrates
Amit Gujarathi
HI @KS13 ,
I trust you are doing great.
Here's a simple onChange catalog client script for your requirement:
    // Regular expression to allow alphanumeric, dashes, and dots/periods
    var regex = /^[A-Za-z0-9-.]+$/;
    if (!regex.test(newValue)) {
        // If the value does not match the regex, show an error message
        g_form.showFieldMsg(control, 'Special characters are not allowed except dashes and dots/periods.', 'error');
        g_form.clearValue(control); // Optionally, you can clear the field value
        // If the value matches the regex, clear any previous error messages
        g_form.hideFieldMsg(control);
Was this answer helpful?
Please consider marking it correct or helpful.
Your feedback helps us improve!
Thank you!
Amit Gujrathi
Hi Amit,
Thank you for the guidance. It works partially. It won't throw the error.
