Restrict non-itil and non-admin users from navigating to native UI by manipulating the URL
Valere Cheudjo
Hello community,
We don't want non-itil and non-admin users to access Native UI platform using web link.
According to the KB : Restrict ESS or non-role users from navigating to native UI by manipulating the URL - Support and Tr...we have implemented this UI Script :
addLoadEvent(function()
if(!g_user.hasRoleExactly('itil') || !g_user.hasRoleExactly('admin') && document.URL.indexOf('.do')!= -1)
window.location='/sp';
else
{return}
Unfortunately, it was redirecting all users (including users with Admin and Itil roles) to the Portal because the link to access our instance contains : ".do"
e.g : https://xxxxdev.service-now.com/login.do
Has someone have any relevant experience to achieve this without using UI Scripts? or how can we improve our UI Script ?
Your contribution would be appreciated
Have you tried excluding the login URL and any other url's that may be part of the login\pw reset prcoess?
A simple fix might be to set data in the user session via the spEntry script and use this session data to identify your 'portal' users (and/or portal), this way you would be referencing data that did not exist until the user had logged in.
Dear Tony,
The issue is the link to access our ServiceNow Instance as you can see in the picture:
The ".do" contains in the UI Script will automatically redirect any user to the Service Portal no matter he has Itil/ Admin role or not.
We have test the script many times, still have the same results
Hello Tera,
I have excluded the login URL and it works.
Thanks a lot !
