Script to replace inactive user and watchlist.
Vijay Baokar
I am trying to write a business rule on user table, suppose if the user becomes inactive then reassign all his change requests which he requested to his manager and if the inactive user is in the watchlist as well then replace him with his manager as well with out overwrite the entire list field.
After (Update)
Active changes to false :
var user = current.getValue("sys_id");// Inactive user
var chg = new GlideRecord("change_request");
  chg.addEncodedQuery("active=true^requested_by=" + user);
  chg.query();
  while(chg.next()){
     var manager = chg.requested_by.manager.toString();
    var whatlst = chg.watch_list.toString();
    var newWatchlist = whatlst.replace(user,manager);
    chg.watch_list = newWatchlist;
      chg.requested_by = manager;
    chg.update();
Is this correct?
Hi @Vijay Baokar ,
I tried your problem in my PDI and it works for me please refer below code
Create before BR
    // Add your code here
    gs.log("Here Check active user");
	var assignedTo = current.assigned_to;
	gs.log("assignedTo = " + assignedTo);
	gr.addQuery('sys_id', assignedTo);
	if(gr.next()){
			gs.log("Chekc active status = " + gr.active);
		if(gr.active == false ||  gr.active == 'false'){
			current.setValue('assigned_to', gr.manager);
})(current, previous);
Result
I assigned change request to any user which is active before, now I'm deactivating that user and now change request assigned to his manager
Result in change request
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
