ServiceNow Integrations – Complete Guide (with Jira Example)
Abhishek_W
Giga Guru
Servicenow Integration-Complete Guide (mostly Rest)
1.What is Integration?
Integration is the process of connecting ServiceNow with external systems (such as Jira, SAP, monitoring tools, or HR systems) so that data can be exchanged automatically and processes can work together seamlessly.
Why do we need Integration?
  • To avoid manual data entry and duplication
  • To keep data consistent across multiple systems
  • To enable end-to-end automation
  • To improve efficiency and reduce human errors
In real projects, ServiceNow rarely works alone—it acts as a central platform connected to many external tools.
2. What is an API and Why Do We Need It?
An API (Application Programming Interface) is a set of rules that allows two applications to communicate with each other.
Why APIs are required in integrations:
  • They provide a secure and structured way to exchange data
  • They define how requests and responses should look
  • They allow real-time or near real-time communication
Types of APIs used in ServiceNow:
  • REST API (most commonly used)
  • SOAP API (legacy systems)
3. What is a REST API?
A REST API is a lightweight, stateless web service that uses HTTP methods to perform operations on data.
ServiceNow heavily uses REST APIs because they are:
  • Simple
  • Fast
  • Language-independent
  • Widely supported
4. REST API Methods
REST APIs use HTTP methods to define actions:
  • GET – Retrieve data
  • POST – Create new records
  • PUT – Update entire record
  • PATCH – Update partial record
  • DELETE – Delete a record
These methods are used in almost every ServiceNow integration.
5. REST Message vs Scripted REST API
REST Message
  • Used for outbound integrations
  • ServiceNow calls an external system
  • Configuration-based with optional scripting
Scripted REST API
  • Used for inbound integrations
  • External systems call ServiceNow
  • Fully scriptable and customizable
6. Integration Scenarios in ServiceNow
1) e-Bonding Integration
eBonding is a bi-directional integration where two systems stay in sync.
  • Inbound: External system updates ServiceNow using Scripted REST API
  • Outbound: ServiceNow updates external system using REST Message
Example:
  • Incident created in ServiceNow → sent to Jira
  • Status updated in Jira → reflected back in ServiceNow
2) Outbound Integration
In outbound integration:
  • ServiceNow is the source system
  • External system is the target
  • Implemented using REST Messages or IntegrationHub actions
3) Inbound Integration
In inbound integration:
  • External system calls ServiceNow
  • Implemented using Scripted REST APIs
7. What is IntegrationHub?
IntegrationHub is ServiceNow’s low-code integration framework that simplifies integrations without heavy scripting.
Why IntegrationHub?
  • Reduces custom scripting
  • Faster implementation
  • Reusable integration logic
  • Built-in error handling
8. What are Spokes?
A Spoke is a collection of pre-built integration actions for a specific external system.
Examples:
  • Jira Spoke
  • Slack Spoke
  • Microsoft Teams Spoke
  • AWS Spoke
How IntegrationHub is different from traditional scripting:
Traditional Integration IntegrationHub
Heavy scriptingLow-code / no-code
Custom error handlingBuilt-in error handling
Hard to maintainEasy to maintain
Not reusableReusable actions
Jira Integration Example (End-to-End)
Scenario: Incident–Jira eBonding
Outbound Flow:
  • REST Message / Jira Spoke sends data to Jira
  • Jira issue ID stored in ServiceNow
Inbound Flow:
  • Jira issue updated
  • Scripted REST API receives update
  • Corresponding incident updated in ServiceNow
This ensures real-time synchronization between ServiceNow and Jira.
💡💡If you find this article any helpful , then give thumbs up 👍.
Dr Atul - LNG
Please add the prefix Blog / Article so it is easy for readers to identify whether the content is knowledge-based or a question
@Dr Atul - LNG  ok I will keep in mind going forward with blogs.
