Subflow Reporting Not Available Even After Setting Flow Reporting to FULL
nitin gupta1
Dear Community,
I am trying to enable reporting for a Subflow so that I can troubleshoot how values are being passed to the Subflow and how the output values are being set.
I have enabled Flow Reporting by setting the relevant system property to FULL. Flow reporting is working as expected; however, I am still unable to see similar reporting details for the Subflow.
Could someone please help me understand:
  • Is there any separate property or configuration required to enable reporting for Subflows?
  • How can I view the input/output values passed during Subflow execution?
  • Is there any additional logging that needs to be enabled for troubleshooting Subflows?
Any guidance would be appreciated.
Thanks in advance!
Ankur Bawiskar
@nitin gupta1
it will only show complete details on new flow which runs after that property is enabled
It won't work for already executing or already finished flows
Hello Ankur,
Thanks for response, yes I am talking about flows that running after the property enables, but the problem with sub flow not with flow.
I wanted to enable reporting with sub flow.
Nitin
