9 hours ago
Hi all ,
var amountA = parseFloat(g_form.getValue('u_amount_a')) ;
var amountB = parseFloat(g_form.getValue('u_amount_b')) ;
var result = amountA - amountB;
g_form.setValue('u_result', result);
Answer is coming in the output NAN .
Could you please help me on this
Thanks and Regards,
Chandan
8 hours ago
Hello @chandan86patra ,
Try this :
if (isLoading) {
var a = parseFloat(g_form.getDecimalValue('u_a')) || 0;
var b = parseFloat(g_form.getDecimalValue('u_b')) || 0;
var total = a + b;
g_form.setValue('u_c', total.toFixed(2));
If this helps you then mark it as helpful and accept as solution .
Aditya
8 hours ago
Hi Chandan
It looks like your u_amount_a and u_amount_b fields are showing a value like “USD;8”.
To get started, you’ll want to parse this so you can create a function to handle it.
Make sure both fields have values before proceeding.
Once you have the values, subtract them from each other and store the result in the Result field.
Here’s a sample code to help you get started:
function getAmount(values) {
if (!values) {
return null;
var parts = values.split(';');
var num = parseFloat(parts[parts.length - 1].replace(/,/g, ''));
return isNaN(num) ? null : num;
var a = getAmount(g_form.getValue('u_amount_a'));
var b = getAmount(g_form.getValue('u_amount_b'));
if (a === null || b === null) {
g_form.clearValue('u_result');
g_form.setValue('u_result', (a - b).toFixed( 2 ));
Just a heads-up if you’re hoping to see changes in either field, you’ll need to set up two OnChange events. One for each Amount field, but make sure to use the same client script for both.
I hope this helps
Ali
