Variable editor not visible on scoped custom application even though configurations are done correct
Resham Noor
I have built 2 custom tables which are request travel and task travel which extends task table.
Variable editor is created on request travel which is working but not working on task travel record.
Formatter: com_glideapp_questionset_default_question_editor
Table: Travel Task
Added it to the form layout but still variables are not visible, No UI policies running on the table, Variables field is already present in the table.
Referred below links:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0538897
https://womennow.sn/posts/custom-table-variable-editor
@Ankur Bawiskar @Alikutty A  @Abhi1 @Community Alums @Amit Gujarathi
Not sure the real issue of variable editor not showing up.
@Resham Noor i am also facing the same issue variable editor is not visible in the custom task table extended from the task  .. did you find the solution for this if yes pls do share it
Chay2
Giga Guru
Hi @Resham Noor ,
Stumbled into same issue, I initally created the formatter in the same scope as the custom table and it didn't work. I deactivated that and created exact same formatter record in global scope, added new formatter to the form view the and it worked. Hopefully this will work for you as well.
Please mark correct or helpful if this makes any impact!!!
Cheers!!
