worknote not updated via fix script for few RITms
07-24-2024 09:59 PM
hi team,
i am running below fix script to cancel flow contexts and update the RITM worknote. but i can see not all ritms are updated with the worknote. Any suggestions??
var ritmGR = new GlideRecord('sc_req_item');
ritmGR.addEncodedQuery("cat_item=cdc93b401b6321904278dbd1f54bcb34^flow_context.flow=e4226b4edba36dd45c82defad3961971^flow_context.stateINWAITING,IN_PROGRESS,QUEUED,CONTINUE_SYNC,PRESUMED_INTERRUPTED,PAUSED"); //Other in Salesforce, cancelling only the old flow related ones
ritmGR.query();
// any old ritm that is in Work in progress state, even if it is closed after the flow change, its flow context will remain waiting. Hence have to cancel all ritm flow contexts in waiting states
var failed_ritms = [];
var flow_cancellation_reason = 'Cancelling incomplete flow contexts';
while (ritmGR.next()) {
// Cancel the Flow
var flowContextGR = new GlideRecord("sys_flow_context");
flowContextGR.addQuery('source_record', ritmGR.getValue('sys_id'));
flowContextGR.query();
while (flowContextGR.next()) {
try {
sn_fd.FlowAPI.cancel(flowContextGR.getUniqueValue(), flow_cancellation_reason);
} catch (e) {
failed_ritms.push(ritmGR.getValue('number'));
// Cancel the Approvers
var approvalGR = new GlideRecord('sysapproval_approver');
approvalGR.addEncodedQuery('document_id=' + ritmGR.getValue('sys_id') + '^stateNOT INapproved,rejected,cancelled,not_required');
approvalGR.query();
while (approvalGR.next()) {
approvalGR.setValue('state', 'cancelled');
approvalGR.setWorkflow(false);
approvalGR.autoSysFields(false);
approvalGR.update();
// Cancel the SCTasks
var taskGR = new GlideRecord('sc_task');
taskGR.addEncodedQuery('request_item=' + ritmGR.getValue('sys_id') + '^active=true^ORstateNOT IN3,4,7');
taskGR.query();
while (taskGR.next()) {
taskGR.setValue('state', '7'); // closed skipped
taskGR.setValue('active', false);
taskGR.setWorkflow(false);
taskGR.autoSysFields(false);
taskGR.update();
//update worknote in RITM
ritmGR.work_notes = 'Cancelling Flow from Fix Script';
// at.setWorkflow(false);// dont set this to false since it will only update the sys_journal table but not the RITM activity journal.
ritmGR.autoSysFields(false);
ritmGR.update();
if (failed_ritms.length != 0) {
gs.log("Failed to cancel the flows of following RITMS:\n" + failed_ritms);
07-24-2024 10:47 PM
In above case when the script is executed, setWorkflow(false) could only stop copying case work notes.
i.e setWorkflow(false); will disable firing of BR on table.
reference:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0867584
How to Update Worknote even the script is executing setWokflow(false)
Please mark helpful & correct answer if it's really worthy for you
BK
07-25-2024 12:16 AM
but my script updates worknotes in dev for all ritms and only in test and prod instances the issue exists where few ritms not updated with worknote, while some are updated.
07-24-2024 10:53 PM - edited 07-24-2024 10:58 PM
Hello @Ravivarman Saee ,
Check-
1. below encoded query logic returns all required number of records or not?
ritmGR.addEncodedQuery("cat_item=cdc93b401b6321904278dbd1f54bcb34^flow_context.flow=e4226b4edba36dd45c82defad3961971^flow_context.stateINWAITING,IN_PROGRESS,QUEUED,CONTINUE_SYNC,PRESUMED_INTERRUPTED,PAUSED"); //Other in Salesforce, cancelling only the old flow related ones2. The "autoSysFields(false)" and "setWorkflow(false)" methods are not affecting to update work notes.
07-25-2024 12:21 AM
yes the query returns the records correctly.
if i set workflow false - then it will not update worknotes in ritm
