Advance view rules script for knowledge
Apaul
I'm working on a View Rule in ServiceNow where I need to display the "People_Zone_View" specifically when the knowledge base is "IT", and fall back to the default view for all other cases. I tried using dot-walking with current.kb_knowledge_base.name but it doesn't seem to be working as expected. Could you help me understand the correct approach for referencing the knowledge base name in a View Rule, or suggest a better way to implement this logic?
Here is the code:
(function overrideView(view, is_list) {
    var answer = view; // Default to the current view
    // Access the knowledge base record
    var kb = new GlideRecord('kb_knowledge_base');
    kb.addQuery('sys_id', current.kb_knowledge_base);
    kb.query();
    if (kb.next()) {
        // Check if the knowledge base name is "IT"
        if (kb.name == "IT") {
            answer = "People_zone_view";
    return answer;
})(view, is_list);
Can anyone help me to solve?
I didn't use the script later as view rule condition was enough to do it bro.
