Audio: Knowledge 2020 Ringtone
05-27-2020 08:27 AM
I've read numerous requests for that music stinger at the beginning of the videos as a ringtone, so here you are... Hear it is:
Android: K2020-Ringtone.mp3
Apple: K2020-Ringtone.m4r
Here's the one from the end of most videos:
Android: K2020-End.mp3
Apple: K2020-End.m4r
and the short transition if you want a text message tone!
Android: K2020-Transition.mp3
Apple: K2020-Transition.m4r
- 2,839 Views
05-27-2020 09:13 AM
Very much excited for this...
Thanks Chuck
05-27-2020 10:02 AM
I just got sucked into an Apple hole. If anyone figures out how to add this ringtone to an iPhone please share.
I've done the following:
1. Attempted this but the file would not "drag and drop" to my device.
2. Attempted this and made it to step #10 but I do not have "Tones" available in my Library.
Note: I have an Apple Music subscription. I own a MAC as well - if that helps.
05-27-2020 10:53 AM
Apple required m4r files last I checked. I added mr4 files above. Check and see if you can get one of those to work.
06-02-2020 06:34 AM
After fiddling around with it for a couple days, this worked for me. Much easier and simpler than I thought. no Apple black hole.
open two Finder windows. One that has the downloaded m4r file, and one that has the iphone open to the "General" tab.
drag and drop from one tab to the other.
on the phone go to setting > Sound & Haptics > Ringtone and set the "K2020-Ringtone"
06-04-2020 11:41 AM
