Exporting variables and variable sets from request item using export definition
Sachin Verma
I am trying to export the request item data using export set, export definition and scheduled export.
Followed this thread https://community.servicenow.com/community?id=community_question&sys_id=38348729dbd8dbc01dcaf3231f961913&view_source=searchResult
But still I am not able to export the variables and variable set.
The exported data looks like :
"records": [
       "request_item.cat_item": "87c068cfdb975c9cb9186033ca9619ba",
       "sc_item_option.value": "3c5939491b489898ac846287bc4bcb3f",
        "request_item": "edec52d3db9714dcb9186033ca9619bf",
        "sc_item_option": "25ecda13db9714dcb9186033ca9619a6",
       "sc_item_option.item_option_new": "fcea6f674f9ee600d2d797411310c71d",
         "request_item.state": "3",
         "__status": "success"
My export definition is
In the List view, the chosen "Fields*" are also not visible :
It appears that the UUID of variables are getting exported.
Please suggest how to get all required "Variables" and "Variable Sets" values exported.
I could see in screenshot for Fields you have added 6 fields
the same fields are seen in 2nd screenshot
correct me if I am wrong
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Hi Ankur,
I am now able to export the variables supplied by user (like multi-line text and select-box),
But I am not able to export the data from "Variable Set" and "reference variables".
When I try to export only sysid is exported, not the the "Display Value".
Sample output :
Reference data variable (Group name) comes from custom table:
"sc_item_option.value": "987a2c02db17109cb9186033ca9619d4",
"dv_sc_item_option": "58eae56cdb7314d856c40d0af49619e0",
"dv_request_item.cat_item": "Secure (PCI) AD User Modify Group Membership",
"dv_request_item": "RITM6608623",
"request_item": "d4eae56cdb7314d856c40d0af49619e2",
"sc_item_option": "58eae56cdb7314d856c40d0af49619e0",
"dv_sc_item_option.item_option_new": "Group Name",
"sc_item_option.item_option_new": "d8f32917db13d0dcb9186033ca96192c",
"dv_sc_item_option.value": "987a2c02db17109cb9186033ca9619d4",
Variable Set data variable (Approving Manager) :
"sc_item_option.value": "55c9c9fddb6ae70cb4a873e78c9619dd",
"dv_sc_item_option": "54eae56cdb7314d856c40d0af49619e0",
"sc_item_option": "54eae56cdb7314d856c40d0af49619e0",
"dv_sc_item_option.item_option_new": "Approving Manager",
"sc_item_option.item_option_new": "00cde3e74f9ee600d2d797411310c74b",
"dv_sc_item_option.value": "55c9c9fddb6ae70cb4a873e78c9619dd",
Can you please suggest if it is even possible to export "Variable Set" and "reference variables" data using Export definition?
Thanks in advance for your help.
Hi Sachin,
you cannot export display value for reference variable or list variable as that is not stored directly in that Variable Ownership table
the values stores are only sys_ids
