How to Sync Jira issues in ServiceNow through jira spoke using API.
SnehaY
I am trying to integrate servicenow with jira and I'm unable sync jira issues in servicenow. Can anyone please help with flow. Thanks in advance.
Chaitanya ILCR
Giga Patron
Hi @SnehaY ,
you can refer this playlist
https://www.youtube.com/watch?v=V4kJTb2jwXs&list=PLqU_zPknanataAu4hK7NlJLBDHmgwvl3h
Chaitanya
In this video I show what's out-of-the-box (OOTB) with the Atlassian Jira Integration for Agile Development in ServiceNow. I am routinely asked about what's possible when it comes to integrating ServiceNow and Jira and I always recommend starting with this pre-built integration. Even if you are ...
Mathieu Lepoutr
Mega Guru
Dear @SnehaY
You could try using Exalate—it’s designed for syncing between ServiceNow and Jira and might simplify the flow you’re trying to set up.
