Auto Technique extraction rule for Azure Sentinel
praveenhams
We have integrated the Azure Sentinel with ServiceNow for Security Incident creation, and it also passes the Tactic and Technique information.
We have enabled the MITRE ATT&CK matrice (Enterprise) and the associated techniques, however, this is only working manually and we would like to populate this information automatically when a SIR is created. We understand that this auto extraction of this information is no longer supported via Incident Profile and we need to create a technique extraction rule. When I created a new extraction rule for Sentinel, we set the Import Table as "Azure Sentinel Incident Import" & Import field as "Incident Raw", Ideally as per the documentation this is good enough to auto populate the MITRE framework in a security incident. However, this is not working as I tried different combinations of import field. Does anybody have relevant experience with auto extracting the MITRE data from Sentinel to ServiceNow SIR?
P.S - I have unchecked the "Ignore auto extraction" option in the extraction rule and enabled auto rollup MITRE information from the alert rules to security incidents.
17 REPLIES 17
Hi @Pooja P ,
After updating the API :
'update this sys_property: sn_sec_sentinel.sentinel_security_incident_api_version
to point to the latest API version: 2024-03-01'
We simply created a mitre technique extraction rule (sn_ti_mitre_tech_extraction_rule) using the sentinel import table (sn_sec_sentinel_incident_import) as the source table and the technique (properties(additionalData(techniques))) as the field.
Pooja P
Thank you for the reply we followed same steps but in Extraction Rule we gave import table as Azure Sentinel Incident Import(sn_sec_sentinel_incident_import) but in Import filed we can see only properties(additionalData(tactics)) field (properties(additionalData(techniques))) is not available.
But this thing is not helping and we can not see any
To have the Techniques, you need to first update the API version, have you done that?
Pooja P
Yes @Greg33 i have updated that.
Unfortunately, If you have updated the API version and still don't see the techniques in the /sn_sec_sentinel_incident_raw table, then the only thing I can suggest is requesting help via a HI case or through Sentinel support
