GlideAjax blocked from Script Include in same scope despite Isolate Script enabled
09-17-2025 08:30 PM
Hi all,
I'm working within the Security Incident Response (SIR) application scope (sn_si) and trying to trigger a Script Include via a client-side UI Action using GlideAjax.
The setup:
- The UI Action and Script Include are both in the sn_si scope
- The Script Include is Client Callable as per the enabled field.
- The UI Action has Isolate Script enabled
- UI Action spits out a warning with:
"Access to Script Include sn_si.SIR_to_CSIS_conversion_UI_Action blocked from scope: sn_si"
I understand that GlideAjax requires the Script Include to be client-callable, but since both components are in the same scope, I expected this to work, especially with Isolate Script enabled.
My Script Include:
var SIR_to_CSIS_conversion_UI_Action = Class.create();
SIR_to_CSIS_conversion_UI_Action.prototype = {
initialize: function() {},
createFromSIR: function() {
var sirSysId = this.getParameter('sysparm_sirSysId');
var result = { success: false, message: '', newRequestId: '' };
var sourceGR = new GlideRecord('table_a');
if (!sourceGR.get(sirSysId)) {
result.message = 'Source record not found.';
return JSON.stringify(result);
if (!gs.nil(sourceGR.u_linked_record)) {
result.message = 'A related record has already been created.';
var targetGR = new GlideRecord('table_b');
targetGR.initialize();
targetGR.description = 'Created from source ' + sourceGR.getDisplayValue('number');
targetGR.setValue('u_field_1', 'value_1');
targetGR.setValue('u_field_2', 'value_2');
targetGR.setValue('u_field_3', 'value_3');
var newId = targetGR.insert();
if (!newId) {
result.message = 'Failed to create the new record.';
// Copy latest work note
var journalGR = new GlideRecord('sys_journal_field');
journalGR.addQuery('element_id', sourceGR.getUniqueValue());
journalGR.addQuery('element', 'work_notes');
journalGR.orderByDesc('sys_created_on');
journalGR.setLimit(1);
journalGR.query();
if (journalGR.next()) {
var latestNote = journalGR.getValue('value');
var noteUpdateGR = new GlideRecord('table_b');
if (noteUpdateGR.get(newId)) {
noteUpdateGR.work_notes = latestNote;
noteUpdateGR.update();
// Update assigned_to
var finalUpdateGR = new GlideRecord('table_b');
if (finalUpdateGR.get(newId)) {
finalUpdateGR.setValue('assigned_to', sourceGR.getValue('assigned_to'));
finalUpdateGR.update();
// Link source to new record
sourceGR.u_linked_record = newId;
sourceGR.update();
result.success = true;
result.newRequestId = newId;
type: 'SIR_to_CSIS_conversion_UI_Action'
};My UI Action:
function createCSISRequestFromSIR() {
var ga = new GlideAjax('sn_si.SIR_to_CSIS_conversion_UI_Action');
ga.addParam('sysparm_name', 'createFromSIR');
ga.addParam('sysparm_sirSysId', g_form.getUniqueValue());
ga.getXMLAnswer(function(response) {
try {
var result = JSON.parse(response);
if (result.success) {
window.location.href = '/table_b.do?sys_id=' + result.newRequestId;
g_form.addErrorMessage(result.message || 'An error occurred while creating the CSIS request.');
} catch (e) {
g_form.addErrorMessage('Unexpected error occurred.');
09-17-2025 10:43 PM
make the new script include as Accessible from "Application scopes" and then try calling
09-17-2025 10:47 PM
@Ankur Bawiskar This is already the case for the script include I newly created
09-17-2025 10:57 PM
Please raise a case with ServiceNow.
09-17-2025 11:02 PM
Thank you for giving your time to take a look
