Add Assignment Group column to Collaborative Work Management Workspace
davideluvotto
Hi all,
It's possibile to add Assignment Group column in the CWM Board view within CWM Workspace?
Davide
I resolve with the support of ServiceNow SPM Team.
You can modify Script include – BoardViewData (API sn_cwm.BoardViewData) and method – getGridColumns (column type Reference).
Please note that this will be customisation and would have to be reverted for smoother upgrade.
D
13 REPLIES 13
D
Are you able to provide exactly what the modification looks like?
As commented by Sunil BN below, in the last versions (>3.x) of SPM, the field Assignment Group is included OOTB within CWM Board, for this reason I revert the customisation.
i was trying to get the assigned_to field onto the card  with state and priority
Sunil B N
In the newer releases (>3.x) you will be able to configure this by just adding into the view of sn_cwm_task table form.
This way, you will not need any customisation and can add and remove any fields. Same can be applied to list and gantt view.
Best regards,
Sunil B N
