Add Assignment Group column to Collaborative Work Management Workspace
davideluvotto
Hi all,
It's possibile to add Assignment Group column in the CWM Board view within CWM Workspace?
Davide
I resolve with the support of ServiceNow SPM Team.
You can modify Script include – BoardViewData (API sn_cwm.BoardViewData) and method – getGridColumns (column type Reference).
Please note that this will be customisation and would have to be reverted for smoother upgrade.
D
13 REPLIES 13
omar10148
@Sunil B N @davideluvotto  Thank you all for your reply,
In fact, me i want to add Number and assignment group also, for assignement group i find it in releases  (>3.x), but i can't add the number also
Do you have some suggestion to help me ?
Best regards,
Sunil B N
Hi, Number is already there as part of OOTB .
Could you please recheck? Possibly it could be hidden in column personalisation.
omar10148
I just rechecked, and I still can't add the number to the CWM. Is there a specific procedure I should follow to display it?
Thanks in advance for your help.
Best regards,
Hi @omar10148,
At present we have CWM 3.1.1 available in the store. This has assignment group (screenshot below) as mentioned by Sunil.
I believe the upcoming version will have the number (screenshot below)
Thank You!
Namita Mishra
