How do I modify a Project Template?
andytom
Once a Project Template is created, how do we edit that template?  Or do we have to create a new Project from the Template, edit the Project and save as a new template?
lsullivan4
I was able to get this to work using the .do links above, but I found it was easier to go to copy an existing project task template record.
You can do this by opening an existing project task with similar details, update the fields as needed, then: Right Click > Insert & Stay.  This copies over the parent task, template, etc without having to fill it in.  It also pulls in the default values that may otherwise be missed.
