Need Script for throwing an error for duplicate entry
malaisamy1
Hi Guys,
I have a requirement as below,
i have a field called 'invoice_no' in a form.
when we open a record which is already created and when we click the button submit it has to give an error 'Duplicate Entry' if the field value(invoice_no) for the record is alreadty there in the another record.
for example:
if in one record the value for invoice_no is : JM1234
and in second record the value for invoice_no is : JM1234   same
then when we click the button(inside any of the record) it has to say that already one record exist for this field invoice_no;
Can someone help me on this scenario?
Thanks in advance
Malaisamy
Use this code in your ui action:
var t=current.getValue('field_name');
var gr=new GlideRecord('table_name');
gr.addQuery('field_name!=""');
while(gr.next())
  if(gr.field_name==t)
  gs.addInfoMessage('There is a record with same invoice number');
  //current.setAbortAction(true);   //use this if you don't want to update the record or use current.update()
  break;
  else
  current.update();
let me know if this helps.
Priyanka
malaisamy1
Hi Priyanka,
It works perfectly... Thanks for the support
Can you please mark the answer correct and close this thread so that others find it useful.
Priyanka.
malaisamy1
Hi Priyanka,
I am not getting the 'correct answer button'. SO that i have marked this as useful.
Let me know if you want me to do anything
Need Script for throwing an error for duplicate entry   open link and mark the correct answer.
Priyanka
